It is currently Fri Aug 22, 2025 2:58 pm
 Post subject: advice for FB removal
PostPosted: Tue Jun 25, 2013 5:46 am
I usually don't deconstruct guitars, so I need some help. I picked up a cheap, probabaly Japanese, plywood classical that I want to fix up for a travel guitar. The factory neck was way too tilted forward and needs to come off and the angle fixed. I need advice on removing the finger board. I assume it has Titebond, Elmer's or a similar glue. Is it enough to use a hot knife to remove the FB, or do I need to heat the board first? If so, what is a good way to heat the board--hair dryer?? Should the frets be pulled first? I plan to junk the FB and install a new one.
PostPosted: Tue Jun 25, 2013 6:46 am
First name: Martin
Last Name: Taylor
City: Central Coast
If you are junking the fretboard, definitely remove frets first. You can heat them or just use some fret pullers. Then use an iron (no steam) to heat up the fretboard and use a palette knife or thin scraper. If you are going to preserve the soundboard, go slow so you don't rip into the soundboard timber. The FB should come off pretty easily.
I actually bought a $20 iron from Aldi (cheap supermarket here in Oz) rather than use the one my wife uses for her Sunday best.
Martin Taylor
http://martintaylorguitars.com.au
PostPosted: Tue Jun 25, 2013 8:49 am
That was probably very wise, as it tends to leave oils on the iron's surface...
PostPosted: Tue Jun 25, 2013 9:41 am
First name: duh
Last Name: Padma
Pull the frets, plane the radius flat thinning the board down to about 1/16...heat with iron and use a putty knife or spatula. The thinner the board the better and faster the heat penetrates. Ironing through a cotton cloth prevents oils sticking to the irons plate. Use the spatula in more of a slight lifting angle instead of a cutting manner to prevent cutting into the necks surface.
PostPosted: Tue Jun 25, 2013 10:59 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
wise advice padma !
PostPosted: Tue Jun 25, 2013 11:05 am
First name: duh
Last Name: Padma
ernie wrote:
wise advice padma !
not bad for an old fool eh! bliss
PostPosted: Tue Jun 25, 2013 11:41 am
All the advice given is dead on. If you're looking to keep the board and frets intact, you can simply lay the iron on top of the frets. It takes a bit longer, but works just fine.
PostPosted: Tue Jun 25, 2013 11:53 am
First name: Tim
Last Name: Allen
City: San Francisco
You don't necessarily need to buy a new iron or use the household iron. Irons often develop water leaks which means that the steam feature no will longer work. At this point people often give them to a thrift store or sell them at a garage sale. As long as it heats up, it makes a perfectly good luthier's tool.
So many tools are unavoidably expensive. Makes it kind of satisfying to get a usable one really cheap.
Tim Allen
"Never hurry, never rest."
PostPosted: Tue Jun 25, 2013 12:28 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
I've got three that my wife thought she threw away. I use one to heat the outside of a side while I'm bending it. It's a little unorthodox, but it has worked well for me. I've spent less than $100 on side bending tools and I'm set up to bend parlor, L-00, dred, and jumbo sides.
PostPosted: Wed Jun 26, 2013 10:03 pm
I've removed a fretboard with the frets installed...a cheap iron and a steel spatula and a little patience proved success. Granted, I had a re-level and seat the frets, but not as bad as bad as taking the top off, :) Keep calm and build on..... Tony
Tony Flippo
PostPosted: Thu Jun 27, 2013 7:58 am
First name: Tom
Last Name: West
State: Nova Scotia
I prefer a heat lamp for removal.
Tom
PostPosted: Thu Jun 27, 2013 8:37 am
Last Name: Sonksen
City: PORTLAND
State: Oregon
Zip/Postal Code: 97216-2013
I've used a small travel iron and my wife's cake frosting metal spatula. Worked great.
PostPosted: Thu Jun 27, 2013 8:40 am
I bought a travel iron for $0.25 at a yard sale.
PostPosted: Thu Jun 27, 2013 1:13 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I got a cheap iron I use for removing fingerboards and bridges... they work very well for the purpose as long as you can keep the iron balanced against the bridge... however some bridges have unusual contours that makes heat transfer very slow and it's really hard to balance the iron on... I was contemplating getting heating blankets for that reason.
Typhoon Guitars
PostPosted: Fri Jun 28, 2013 11:23 am
I broke down and bought a heating blanket for bridge removal - what a difference! Really makes the process much easier. I'll be getting one for fretboards and FB tongue next.
PostPosted: Mon Jul 01, 2013 4:50 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
Tom
I also use a heat lamp (250W). A white corrugated cardboard shield is use to keep the heat off the finish of the soundboard and peghead.
On many occasions, I have reused the fingerboard, which was removed to install or change the neck reinforcement. In those instances, I normally leave the frets in place.
PostPosted: Mon Jul 01, 2013 9:45 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Padma , your not a fool, just older and wiser lol. Yup u can pick up used irons for under $2
